Community Member
How to import CAD files to WLSE
How to import building/floor map in Auto CAD format to WLSE ?
Blue
Re: How to import CAD files to WLSE
WLSE do not support importing AutoCAD files as maps. Only .gif, .jpg, .jpeg, or .png is supported
Community Member
Method A: Raster File Export from the Print Menu:
1. Open an AutoCAD file and choose "Printer Setup" from the file menu.
2. In the Preferences section, choose "New."
3. In the "Add a Printer" section, choose "Raster File Export AD 4.3 by AutoDesk."
4. Respond to prompts, selecting "800x600 pixels" * and "TIFF."
5. In the preference menu, select OK and "TIFF Export."
6. Choose File menu and "Print."
7. In the Device & Default Section, choose "TIFF Export," then "OK."
8. Choose "OK" in the print/plot configuration.
9. The TIFF file is now visible in the default folder.
10. Open the TIFF file in PhotoShop or comparable program.
11. Crop the image or adjust the canvas size to the desired width in pixels/
12. Optimize for the Web and save as a GIF.
139
