How to mornitor VSS (Virtual Switching System) & Stack (Switch) By Cisco Prime Infrastructure
Dear all,
I have 02 C6504-E with VSS (Virtual Switching System)
   and 02 C3750X-24T-L used Stack
How to you Cisco Prime Infrastructure to monitor VSS & Stack tatus?
Thanks.
I don't have a PI but I think you can add the stack as a normal switch and the PI will detect how the device is configured via SNMP show the device's status.
Rating useful replies is more useful than saying "Thank you"
Hi Amjad,
Of course I can monitor 02 Stacked SWs as a normal SW.
What I want to talk is that: How to monitor below things:
- Stack status: Master/Slaver...
- Other stack elements
- Stack status change Alarm
- Stack port down Alarm
Many thanks
Re: How to mornitor VSS (Virtual Switching System) & Stack (Swit
If you look at the Prime Infrastructure Device List you'll see there's a limit set of features that it supports, VSS isn't one of them, just the basic information
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/1.2/supported/devices/CPI12_supported_devices.xlsx
Cheers,
John
713
