How to NAT with different public IPs in ASA 8.3?
I'm starting up with a firewall project and I was wondering how to NAT. I have Cisco ASA 5510 with v.8.3.
I want to NAT different interfaces with different public IPs.
Outside is:
  • outside (interface 0/0)   x.x.x.87/24
I have three "inside" interfaces:
  • inside (interface 0/1.5)     192.168.5.1/24
  • wlan (interface 0/1.20)     192.168.20.1/24
  • guest (interface 0/1.60)     192.168.60.1/24
All traffic from inside should have public IP of x.x.x.87 (== outside)
All traffic from wlan should have IP of x.x.x.88
All traffic from guest should have IP of x.x.x.89
Should I do network objects of those public IPs and NAT different interfaces to those? Example would be great. Thanks...
Petri
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: How to NAT with different public IPs in ASA 8.3?
Hi Petri,
its quite simple,
define global pools first,
global (outside) 1 interface
global (outside) 2 x.x.x.88
global (outside) 3 x.x.x.89
then nat rules
nat (inside) 1 192.168.5.0 255.255.255.0
nat (wlan) 2 192.168.20.0 255.255.255.0
nat (guest) 3 192.168.60.0 255.255.255.0
also don't forget to define nat0 access list for traffic you dont want to nat and apply it as follows
nat (inside) 0 acess-list nat0
nat (wlan) 0 acess-list nat0
nat (guest) 0 acess-list nat0
Irakli
Hi Petri,
its quite simple,
then nat rules
Irakli
Thanks Irakli for the quick reply.
BR,
Petri
790
