How to test/monitor device traffic
Let's say I have a non-pc device (medical equipment) that will be put on an wpa2 eap-peap network.  How would you go about listening to the traffic between the AP and the Device to verify it's roaming correctly and has no other issues for testing purposes?
1 REPLY
Roaming behavior can be checked using WLC>debug client while continuous ping going to the device.
Packet capture over the air:-
https://supportforums.cisco.com/docs/DOC-19232#comment-9627
171
