IAS and MAC authentication
Hi, I´m having some trouble to authenticate the users with EAP and MAC authentication, i´m using IAS server and the EAP authentication is working well, but when I configure the MAC and EAP authentication, it doesn´t connect to the clients.
Any idea how can I solve this problem??
Thansk
1 ACCEPTED SOLUTION
Silver
Re: IAS and MAC authentication
I think MAC authentication is not supported in IAS , you can do MAC address filtering on AP
Silver
uummm, maybe I´ll have to use ACS to eliminate all this problems, thanks for your help
178
