Community Member
Identity Services Engine (ISE) support for the WLC 2500
Is the ISE going to support the 2500 series Wireless LAN Controller WLC? If yes in what release and appriximately when is that due to be released?
1 REPLY
Your question is disturbing. ISE is (amongst other things) a radius server. WLC 2500 can use radius servers for authentication. So it's supported.
Any device doing radius is supported with ISE ...
Now you are maybe referring to a particular feature in ISE ?
1014
