idsm2 reload
We have one Catalyst 6509 with IDSM2, and the IDSM2 reboot unexpectedly. The error message is :
Nov 17 22:32:47: %OIR-SP-3-PWRCYCLE: Card in module 9, is being power-cycled off (Module not responding to Keep Alive polling)
Nov 17 22:32:48: %C6KPWR-SP-4-DISABLED: power to module in slot 9 set off (Module not responding to Keep Alive polling)
Nov 17 22:36:21: %DIAG-SP-6-RUN_MINIMUM: Module 9: Running Minimum Diagnostics...
Nov 17 22:36:22: %MLS_RATE-4-DISABLING: The Layer2 Rate Limiters have been disabled.
Nov 17 22:36:22: %DIAG-SP-6-DIAG_OK: Module 9: Passed Online Diagnostics
Nov 17 22:36:23: %OIR-SP-6-INSCARD: Card inserted in slot 9, interfaces are now online
Nov 20 18:47:26: %OIR-SP-3-PWRCYCLE: Card in module 9, is being power-cycled off (Module not responding to Keep Alive polling)
Nov 20 18:47:26: %C6KPWR-SP-4-DISABLED: power to module in slot 9 set off (Module not responding to Keep Alive polling)
Nov 20 18:51:00: %DIAG-SP-6-RUN_MINIMUM: Module 9: Running Minimum Diagnostics...
Nov 20 18:51:01: %MLS_RATE-4-DISABLING: The Layer2 Rate Limiters have been disabled.
Nov 20 18:51:01: %DIAG-SP-6-DIAG_OK: Module 9: Passed Online Diagnostics
Nov 20 18:51:01: %OIR-SP-6-INSCARD: Card inserted in slot 9, interfaces are now online
It occured several times before 11/17 and I have tried to reseat the module before, but the IDSM2 reboot again. The IOS version of supervisor engine is s72033-ps-mz.122-18.SXD5.bin, The IDSM2 software version is 6.0(5)E2. Please help to diagnosis this problem. Shall I upgrade IOS of supervisor engine or IDSM or need RMA?
Best Regards,
Jackson Ku
1 REPLY
Re: idsm2 reload
you posted this in the Wireless Security section, please move your question to the Security section. I'm not sure you will get much replies here :-)
Nicolas
335
