implementing HREAP over WLAN
  Gday All,
Trying to implement HREAP over WAN between main and remote site. The WLC4402 is on main site. There will be a secondary DHCP at the remote site. Does the switch at the remote site any preparation?
Thank You,
Shankar Pariyar
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
have you already configured the AP for HREAP and the native VLAN?
if you have, then you only need to make the switchport a trunk, with the correct native vlan set.  you should aslo prune the VLAN that do not need to be allowed to the wireless users.
If you havn't configured the AP yet.
You can have the AP be on a trunk port, with the native VLAN set, as the AP won't be sending a tag at this point.  Once the AP joins, change the mode to HREAP, set the native VLAN.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hall of Fame Super Silver
Re: implementing HREAP over WLAN
Just to add to Steve's post. Here is a link describing if you should configure the switchport as a trunk port or not.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080736123.shtml#Trunk
Sent from my iPhone
-Scott
HTH,
Steve
thanx Steve.
Can I just add one more info, the APs are LightweightAPs. Does it change anything?
Sent from my iPhone
-Scott
Thanx ScottFella, I was reading the same doco too. Will let you know how I go.
Cheers!!
447
