Community Member
indoor mesh wireless
morning friends,
One of our buildings is a 120K square foot building with very high public access. We currently have 5 independent AP's where some Cisco, others are not and each one broadcasts a different SSID. Like others I am sure it just evolved out of need. Time to replace.
I am looking to implement a wireless solution that can achieve the following and hoping someone here can suggest a CISCO product line to investigate.
An easily expandable indoor wireless mesh solution that can provide a single SSID that is would be accessed by mainstream public. (open - free wifi)
AND
another single SSID that would be hidden that would be for internal staff and management, and etc...
ultimately it would be managed by one console / system / device.
Any thoughts?
thanks
Blu
VIP Purple
Hi,You can go with Cisco UWN
You can go with Cisco UWN Solution.
Its based on WLC and AP.
You just have to configure the WLC and just have to plug the AP to swicth.
Which WLC: depends on your requirement(2504 wlc if you not require more then 10 AP).
More info abt wlc:http://www.cisco.com/c/en/us/products/wireless/wireless-lan-controller/index.html?referring_site=smartnavRD
Info About AP:http://www.cisco.com/c/en/us/products/wireless/access-points/index.html
hope it helps.
Hall of Fame Super Gold
Duplicate postGo here:  https
Duplicate post
Go here:  https://supportforums.cisco.com/discussion/12237961/seeking-indoor-wireless-mesh-solution
137
