02-28-2012 01:02 AM - edited 07-03-2021 09:40 PM
Hallo,
I would like to integrate our intranet web page with Cisco WLC 2500. Is it possible to integrate custom web page with WLC. I know, that I can create custom authentication page, but what about creation of the user?
MatejM
02-28-2012 01:09 AM
You can either use the default page, a customized webauth bundle or use an external web server. When using any of these, the username and password will be either placed in the wlc or authentication can point to a radius server.
02-28-2012 04:51 AM
Thanks for reply,
I know all about authentication page and authentication procedure. My question was, how can I integrate WLC and my custom webpage or application. Not for authentication users, but I would like to create temporary users (users with limited logon time) with customized web page or application.
MatejM
02-28-2012 07:18 AM
I guess you would have to script something that logs into the wlc and enters cli commands to add or remove the temporary users. No real integration with 3rd party apps. You could possibly also do it with snmp.
02-29-2012 01:15 AM
Yes, you guess right. Thanks for answer.
MatejM
02-29-2012 02:36 AM
Good guess huh:) interesting setup I must say.
