Integration between WLC 5508 and Microsoft NPS 2008
Hi guys,
Any of you, have working guidance for WLC 5508 and Microsoft NPS 2008 integration?
I managed to configure Wireless 802.1x feature (PEAP) but it failed. I'm running software ver. 7.0.116.0.
Is there any bug related 802.1x on this software version?
thanks in advance.
BR
shendy
1 REPLY
Hi Shendy,
I am not aware about any bug related to this. I think you better check all configuration and make sure it is fine.
Logs from NPS and WLC (and possibly from the supplicant) may guide you where the problem resides.
What does the NPS logs tell about the reason of the authentication failure?
What does the WLC logs say about the failure (check show msglog and show traplog).
- Make sure the Radius server added correctly with correct IP and correct shared secret on WLC.
- Make sure that the radius is configured correctly to allow PEAP-MSCHAPv2.
- Make sure WLC is added successfully to WLC with correct IP address and correct shared secret.
- Make sure the clients are correctly configured and the server's (NPS) certificate is trusted on the clients.
Amjad
Rating useful replies is more useful than saying "Thank you"
698
