Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Intra-WLAN filtering with/without Flexconnect local switching
Hi all,
          I don't seem to be able to find information regarding Intra-WLAN filtering for the WLC? (e.g. I need connected wifi devices filtered from each other on the same WLAN)  I assume it can be done?  and if possible I assume FlexConnect affects how it is done?  Is there a different term than Intra-WLAN filtering?
Any links/pointers to the documentation so I can RTFM on this would be much appreciated....:)
1 ACCEPTED SOLUTION
In the WLC it's called Peer
In the WLC it's called Peer-To-Peer Blocking
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_01001111.html
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
It certainly did.  Thanks
It certainly did.  Thanks Steve.
40
