Iphone and machine based authentication
Hi ,based on the below discussion. trying to understand if idevices like iphones or ipads, support machine based authentication?
https://supportforums.cisco.com/message/3322972#3322972
thanks
Anna
Everyone's tags (4)
Hall of Fame Super Silver
Re: Iphone and machine based authentication
I don't believe they can. The reason I say this is because when using machine authentication for a Windows PC, they are joined to the domain. So unless you can add them to the domain, you will not e able to do machine authentication.
-Scott
Anna:
The doc you provided say they are not. Inside the page you provided there is a link:
https://supportforums.cisco.com/docs/DOC-21756
I quote:
Now the iPhones and iPod touches are able to connect to the secure WLAN with only their AD credentials. They are then prompted to accept the certificate and granted access to the secure WLAN. The domain machines require certificate to be installed via group policy, but the question is how the Apple devices are pulling down the cert?
How to block this behavior?  These devices should only use the guest web-auth access.
Rating useful replies is more useful than saying "Thank you"
394
