atc
Community Member
Is Network EAP necessary for WPA/TKIP+LEAP?
a 3rd party wireless client cannot connect to the Cisco AP configured with following setting:
Encryption: TKIP
Authentication: OPEN+EAP
Key Management: Mandatory+WPA
Corporate Server: Local Radius Server
Local Radius Server: LEAP
Someone told me Network EAP is required for LEAP authentication. Can anyone tell me about if Network EAP is required?
Community Member
Re: Is Network EAP necessary for WPA/TKIP+LEAP?
WPA is the combination of an underlying EAP +the WPA key management function
atc
Community Member
Hi, bwalchez,
Thanks for your reply.
But what I want to confirm is:
When I use LEAP as the underlying EAP type, Do I need to enable 'Network EAP' as Authentication Method and Is it necessary for the client to use Network EAP as the Authentication Method.
Thanks.
Silver
Hi Junming,
for non-Cisco Clients your assumtion is right!
Best regards,
Frank
182
