ISE 1.1.1 cisco-av-pair:Wireless-WCS
Has anyone configured ISE yet to authenticate WCS against ISE using RADIUS?  I have created the Authorization Profiles with rule0=SuperUsers, tack0=...ect, but I am wondering how everyone has done the authentication and authorization rules.  Any lessons learned would be great.
Kyle
Everyone's tags (5)
Doesnt look like it will be simple, you will have to create the authorization profile where you will have to manually add all the av pairs.
Tarik Admani
*Please rate helpful posts*
Tarik Admani *Please rate helpful posts*
I cannot seem to add any more tasks past task9. I get the following error:
Bad Request Parameters. Scripts in input fields will not be processed. Please Remove Markup
Maybe there is an issue with how many lines I can have?
Kyle,
Do you have patch 1 installed, I am going to try on my setup to see if it is a bug.
Tarik Admani
Re: ISE 1.1.1 cisco-av-pair:Wireless-WCS
Yes, I have patch 1 installed.  I am trying to add the following cisco-av-pairs:
Wireless-WCS:role0=Admin
Wireless-WCS:task0=Users and Groups
Wireless-WCS:task1=Virtual Domain Management
Wireless-WCS:task2=Audit Trails
Wireless-WCS:task3=TACACS+ Servers
Wireless-WCS:task4=RADIUS Servers
Wireless-WCS:task5=Logging
Wireless-WCS:task6=License Center
Wireless-WCS:task7=Scheduled Tasks and Data Collection
Wireless-WCS:task8=User Preferences
Wireless-WCS:task9=System Settings
Wireless-WCS:task10=View Alerts and Events
Wireless-WCS:task11=Email Notification
Wireless-WCS:task12=Delete and Clear Alerts
Wireless-WCS:task13=Pick and Unpick Alerts
Wireless-WCS:task14=Ack and Unack Alerts
Wireless-WCS:task15=Configure Controllers
Wireless-WCS:task16=Configure Templates
Wireless-WCS:task17=Configure Config Groups
Wireless-WCS:task18=Configure Access Points
Wireless-WCS:task19=Scheduled Configuration Tasks
Wireless-WCS:task20=Migration Templates
Wireless-WCS:task21=Configure Choke Points
Wireless-WCS:task22=Configure Spectrum Experts
Wireless-WCS:task23=Configure ACS View Servers
Wireless-WCS:task24=Auto Provisioning
Wireless-WCS:task25=Monitor Controllers
Wireless-WCS:task26=Monitor Access Points
Wireless-WCS:task27=Monitor Clients
Wireless-WCS:task28=Monitor Tags
Wireless-WCS:task29=Monitor Security
Wireless-WCS:task30=Monitor Chokepoints
Wireless-WCS:task31=Monitor Spectrum Experts
Wireless-WCS:task32=RRM Dashboard
Wireless-WCS:task33=Mesh Reports
Wireless-WCS:task34=Client Reports
Wireless-WCS:task35=Performance Reports
Wireless-WCS:task36=Security Reports
Wireless-WCS:task37=Compliance Assistance Reports
Wireless-WCS:task38=Voice Audit Report
Wireless-WCS:task39=Config Audit Dashboard
Wireless-WCS:task40=Location Server Management
Wireless-WCS:task41=View Location Notifications
Wireless-WCS:task42=Maps Read Only
Wireless-WCS:task43=Maps Read Write
Wireless-WCS:task44=Client Location
Wireless-WCS:task45=Rogue Location
Wireless-WCS:task46=Planning Mode
Wireless-WCS:task47=High Availability Configuration
Wireless-WCS:task48=Health Monitor Details
Wireless-WCS:task49=Configure WIPS Profiles
Wireless-WCS:task50=Global SSID Groups
Wireless-WCS:task51=WIPS Service
Wireless-WCS:task52=Configure Lightweight Access Point Templates
Wireless-WCS:task53=Configure Autonomous Access Point Templates
Wireless-WCS:task54=Guest Reports
Wireless-WCS:task55=Handover Server Management
Wireless-WCS:task56=Monitor Handover Server
Wireless-WCS:task57=Configure Ethernet Switch Ports
Wireless-WCS:task58=Configure Ethernet Switches
Wireless-WCS:task59=Monitor Interferers
Wireless-WCS:task60=Device Reports
Wireless-WCS:task61=Network Summary Reports
Wireless-WCS:task62=Compliance Reports
Wireless-WCS:task63=CleanAir Reports
Wireless-WCS:task64=Report Launch Pad
Wireless-WCS:task65=Run Reports List
Wireless-WCS:task66=Saved Reports List
Wireless-WCS:task67=Report Run History
Wireless-WCS:task68=Automated Feedback
Wireless-WCS:task69=TAC Case Attachment Tool
Wireless-WCS:task70=Ack and Unack Security Index Issues
Wireless-WCS:task71=View Security Index Issues
Wireless-WCS:task72=Monitor Media Streams
Wireless-WCS:task73=Voice Diagnostics
Wireless-WCS:task74=ContextAware Reports
Kyle
I see the same issue on my box after task9 also, there is an internal bug that Cisco is going to fix in release 1.2 the issue is with the "Alerts" word in the attribute. If you change the spelling then it will work. Here is what I pulled up on the bug itself, hopefully once it is is scrubbed it will come back with the full details.
CSCty27722            Bug Details
Dear valued Cisco Bug Toolkit customer, the bug  ID CSCty27722 you searched contains proprietary information that cannot  be disclosed at this time; therefore, we are unable to display the bug  details. Please note it is our policy to make all externally-facing bugs  available in Bug Toolkit to best assist our customers.  As a result,  the system administrators have been automatically alerted to the  problem.
While we are working to resolve this issue, we invite you to reach out to the experts on the Bug Toolkit Support Community.  You may find answers there to your Bug Toolkit questions, or post your feedback on our forum as well.  Thank you.
Note: Some product enhancement requests and documentation bugs may not be available in Bug Toolkit.
Thanks.
Tarik Admani
So there is no fix or official bugid yet ? I just tried it in the 1.2 beta, and it works there.
Also, if you change the wording in the av-pair, then your authz profile won't work with the WCS/Prime.will it ?
Re:ISE 1.1.1 cisco-av-pair:Wireless-WCS
This is an acs bug supposedly fixed in 5.3 patch 6 but I have not yet been able to perform the upgrade to confirm that.
Sent from Cisco Technical Support Android App
1641
