ISE and WLC
Dear friends,
We are using ISE and WLC integrity in our network, we have Corporate and Guest SSID, we configured it but client cant connect to this ssid and cant be authenticated, please see attached files and tell me if i done something wrong in configuration of WLC
10.10.17.201 is ISE
Thank you for attention
Everyone's tags (1)
Hall of Fame Super Gold
Can your wireless client
Can your wireless client associate to the Guest SSID if it was OPEN authentication?
Yes, i created addional WLAN
Yes, i created addional WLAN with only open authentication and it works
Just to Share:https:/
Just to Share:
https://supportforums.cisco.com/document/70751/integration-ise-identity-services-engine-cisco-wlc-wireless-lan-controller
Bronze
Hi,After viewing the Trap
After viewing the Trap logs it seems you have checked on validate machine.
On the client side, make sure you don't check validate machine and then try.
Please post your Live
Please post your Live authentication details from ISE  , go to operation> authentication> logs
Also post the authentication/ authorization rules here.
I would also like you to Refer below:
http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/115732-central-web-auth-00.html
154
