ISE web portal problem
Dear Friends,
I configured my 5508(in sso) and i made authentication through 802.1x on our software ISE,  i spent time to enable WEB portal authentication for guest users(guest wlan), so many guides for web portal authentication, my ACL on WLC shows hits for DNS traffic, when i connect to my GUEST wlan, i see ISE URL portal in my CLIENT security information, but nothing happens, when i use my browser to connect somewhere it doesnt redirect me to ISE, please show me the last guide or something about it
thank you
Everyone's tags (1)
VIP Purple
Hi Kamarn,
please check with this document:
Central Web Authentication (CWA) for guests with ISE
https://supportforums.cisco.com/docs/DOC-26442
Identity Services Engine Guest Portal Local Web Authentication Configuration Example
http://www.cisco.com/en/US/products/ps11640/products_configuration_example09186a0080c13287.shtml
Hope this helps.
Dont forget to rate helpful posts
I used exactly this guides, the last check about security information in WLC is the same as on my WLC, but when i enter any url to my browser connect to guest nothing happens
Re: ISE web portal problem
Are they guest anchor setup.
Are redirect url getting pushed.
Wlc code?
273
