Issue Apply Dynamic Interface from Prime
Willem de Groot
Hi all,
I have some problems applying a Dynamic Interface Template from prime to my WLC:
Prime: 1.3.0.20 Update 4
WLC 5508 / 7.4.110.0
I can Apply this template to older WLC versions.
The LAG mode is enabled on my WLC.
Any Idea?
Willem
5 Replies 5
Sandeep Choudhary
what is the error you are facing???
Can you paste the screenshot.
If I click on "apply to controllers..." there is a list of controllers but the controller I want to apply the template to is not in this list (new controller, the first 7.4 connected to this prime, the other controllers are 4402 or 5508 all with 7.0.235.0) .
If I clear the LAG flag, there is one controller in the list but also not the one I want to apply the template to.
The controller will show up in other lists like "NTP".
I can also apply NTP Servers to this controller, what means that in general the communication is possible.
1. is the 7.4v controller is connected to prime infra????
2. can you check again on WLC, is LAG enabled on 5508 or not ?
Hi I found it , if I scroll down the list I'll find it
I think I have to get used to the huge white screen part below the small scrollable Information part
Great that finally you scrolled down to check it. Same things happened with me when frist time I was configuring WLC via WCS.
Dont forget to arte helpful posts and mark the question as answered, it may help others.
