01-29-2014 05:20 AM - edited 07-05-2021 12:03 AM
Hi all,
I have some problems applying a Dynamic Interface Template from prime to my WLC:
Prime: 1.3.0.20 Update 4
WLC 5508 / 7.4.110.0
I can Apply this template to older WLC versions.
The LAG mode is enabled on my WLC.
Any Idea?
Willem
01-29-2014 05:33 AM
what is the error you are facing???
Can you paste the screenshot.
01-29-2014 05:42 AM
If I click on "apply to controllers..." there is a list of controllers but the controller I want to apply the template to is not in this list (new controller, the first 7.4 connected to this prime, the other controllers are 4402 or 5508 all with 7.0.235.0) .
If I clear the LAG flag, there is one controller in the list but also not the one I want to apply the template to.
The controller will show up in other lists like "NTP".
I can also apply NTP Servers to this controller, what means that in general the communication is possible.
01-29-2014 05:52 AM
1. is the 7.4v controller is connected to prime infra????
2. can you check again on WLC, is LAG enabled on 5508 or not ?
01-29-2014 05:54 AM
Hi I found it , if I scroll down the list I'll find it
I think I have to get used to the huge white screen part below the small scrollable Information part
01-29-2014 05:58 AM
Great that finally you scrolled down to check it. Same things happened with me when frist time I was configuring WLC via WCS.
Dont forget to arte helpful posts and mark the question as answered, it may help others.
