Issue regarding WLC and ACS (RADIUS) authentication method
Hi guys,
There is any option to configure WLC to authenticate with the ACS(RADIUS) without using Certificate?
And if so, can you please send me the guide for it.
Silver
Hello Liad,
would you please confirm if you want to configure authentication for WLC login through radius?
or WLAN login?
Kind regards
Talal
Silver
Hello Again,
if you want to configure radius server to manage WLC itself / login for WLC , please follow this guide
http://www.cisco.com/en/US/partner/tech/tk722/tk809/technologies_configuration_example09186a0080782507.shtml
but if you want to use it for WLAN login. you can use EAP-FAST or LEAP.
here is document for EAP-fast configuration
http://www.cisco.com/en/US/partner/products/ps6366/products_configuration_example09186a00808e5d6b.shtml
for leap , WLC configuration is same , the difference would be on client. and on ACS to add the chexbox that allow LEAP.
hope this helps
Talal
please rate replies that you find useful ,and if question is answered , mark it as answered
I need to authenticate a user via the radius server(not the WLC)
I dont need to authenticate a user for the WLC..
Just a normal user that need to gain access to the WLAN.
Regards.
Hall of Fame Super Silver
If you use any type of radius for wireless user authentication, then you most likely will be using 802.1x, which does require a certificate.  Even if you did local ACS users, the ACS would require a certificate installed for 802.1x.  If you do not wish to use a certificate, then you would have to go with pre-shared keys and you wouldn't be using the readius.
-Scott
Silver
Hello Fella
it depend on the protocol used
EAP-TLS ->> require 2 certificate
PEAP ->> require 1 certificate (server)
EAP-FAST ->> no certificate required , can use PAC's
LEAP , only require usernam and password , but works only with some utility ->> not working with default windows zero configuration , same applies to EAP-FAST.
Kind regards
Talal
I know... just being specific to what is normally used.  I didn't want to get Liad confused on this subject.
-Scott
353
