Issue with LEAP configuration for repeater.
if i could please have some assistance with getting leap to work properly on my repeater it'd be greatly appreciated
below is the ap root configs setup w/ leap authentication .. leap is working fine on that.. i am able to authenticate to the ap but not the repeater
AP CONFIGS ---------------------------
aaa new-model
aaa group server radius rad_eap
server 10.246.1.108 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 syslog
dot11 ssid ITT_AP1
   authentication open eap eap_methods1
   authentication network-eap eap_methods1
   authentication client username telco password 7 02140D58001F02
   guest-mode
username Cisco password 7 05280F1C2243
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit 7 2E0F7F53076C transmit-key
encryption mode wep mandatory
ssid ITT_AP1
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
  nas 10.246.1.108 key 7 0653027143190141041B1E5E
  user telco nthash 7 052F202A04696B5A4A554431285851780A720E6267763122425B54060D0E06055B
  user timmyah nthash 7 062359036E6B51485645435A55517A7E71096310754326412250707A7E07005F21
  user litovill nthash 7 08036E685E3D544240532D220B7306781511064757375623040C0B02762C214E32
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.246.1.108 auth-port 1812 acct-port 1813 key 7 1547065C0B7D237C293F3977
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
REPEATER CONFIGS ------------------------------------
aaa new-model
dot11 syslog
dot11 ssid ITT_AP1
   authentication client username telco password 7 071D284F451014
   guest-mode
   infrastructure-ssid optional
username Cisco password 7 072C285F4D06
bridge irb
no ip address
no ip route-cache
encryption key 1 size 40bit 7 A9966F53085E transmit-key
ssid ITT_AP1
parent 1 000d.2888.c91f
station-role repeater
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp
no ip route-cache
ip http server
radius-server host 10.246.1.108 auth-port 1812 acct-port 1813 key 7 115C14551845035405262771
bridge 1 route ip
line con 0
line vty 0 4
end
288
