issue with privilege level on access point
I've been trying to config 2 access point with limited access to add mac address and save the running config to startup config for selected helpdesk user. When the user login the correct privilege level is applied but when they try to save running config t start up config they getting permission denied.
Router Config
aaa authentication login RAD_AUTH group radius local
aaa authorization exec default group radius local
radius-server host 1.1.1.1
radius-server host 2.2.2.2
radius-server key 7 sample
privilege configure all level 5 access-list
privilege exec all level 5 copy running-config startup-config
privilege exec level 5 copy running-config
privilege exec level 5 write memory
privilege exec level 5 configure terminal
Error when saving
AP1#copy running-config startup-config
Destination filename [startup-config]?
startup-config file open failed (Permission denied)
AP1#sh privilege
Current privilege level is 5
Radius Config
issue resolve by adding "file
issue resolve by adding "file privilege 5" under global config
Hi.+5 for you for sharing the
Hi.
+5 for you for sharing the answer. Thank you. I am glad that it worked with you.
Can you please tell us what AP model that you are using?
Amjad
Rating useful replies is more useful than saying "Thank you"
85
