Issues Connecting to new 5500 WLC
I have an existing 4400 that is connected to the network and it is managing a single old Cisco AP.  It has been installed for about 6 years.
I've just added a new 5500 (intending to replace the 4400) to the environment along with new 2602 WAP's.  The 5500 uses port 1 with a
1000BASE-T SFP connection into a 2960 switch.  On both ends of the connection I am using StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module Mini-GBIC's - 10/100/1000Base-T Copper SFP Module .
The 5500 is configured with an IP address, 255.255.0.0 mask and has the gateway address in it.
I have no problems accessing the 5500 via the service port and viewing/changing the configuration.
But I cannot cannot ping the 5500 from the network,
nor can the 5500 ping any devices, including the switch that it is connected to.
I could be suspicious of the GBIC's but there are no obvious errors showing in the statistics and some data seems to be passing between the 2960 and the 5500.
I've tried setting the VLAN to 0 and to 100 after reading some posts.
The port on the switch #23 shows that it is trunked.  I enabled fastport for it.
Any troubleshooting ideas?
Thanks in advance.
Everyone's tags (2)
VIP Purple
Re: Issues Connecting to new 5500 WLC
Hi Rob,
It is looks like trunking between switch port & WLC is not correct. configure it like below & try it again
G1/0/23
sw mode trunk
sw trunk native vlan   If htere is no specific native vlan leave it to default 1
sw trunk allowed vlan 100,x,y  where x, y are normal user vlans intend to configure on this WLC
spanning-tree portfast trunk
in WLC
config  interface address management   255.255.0.0
config  interface vlan management 100
config  interface port management 1
You need to be given WLC management IP in vlan 100 & SVI for vlan 100 to be defined on your L3 switch. That SVI IP should be the gateway address in the above WLC config line.
Still if this does not work post your "show interface detail management" output
Rasika
I did the commands but I am not seeing any success with ping.
Interface Name................................... management
MAC Address...................................... e8:b7:48:a1:e8:80
IP Address....................................... 10.29.1.242
IP Netmask....................................... 255.255.0.0
IP Gateway....................................... 10.29.1.245
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 100
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 10.29.1.201
Secondary DHCP Server............................ 10.95.9.1
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Disabled
VIP Purple
On the switch side give this output where x/x is the WLC connected switch port
show run int x/x
show interface x/x
show interface trunk
show span vlan 100
I hope physical link is up
Here is the switch port information:
I
FastEthernet0/23 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0cd9.9654.0017 (bia 0cd9.9654.0017)
  Description: WLC 5550 242
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:07, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 235 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     1420055 packets output, 310035787 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
VIP Purple
Your switchport is Fast Ethernet, WLC expect this to be a Gig port
Change trunk to G0/1 or G0/2 if that available in this 2960 switch. This may be the problem
Here are the other items.
Building configuration...
Current configuration : 305 bytes
interface FastEthernet0/13
switchport mode access
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
macro description cisco-desktop
spanning-tree bpduguard enable
end
APWNOGSW102#show interface trunk
Port        Mode             Encapsulation  Status        Native vlan
Fa0/23      on               802.1q         trunking      1
Fa0/27      on               802.1q         trunking      1
Fa0/31      on               802.1q         trunking      1
Fa0/46      on               802.1q         trunking      1
Fa0/47      on               802.1q         trunking      1
Fa0/48      on               802.1q         trunking      1
Gi0/1       on               802.1q         trunking      1
Gi0/2       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/23      100
Fa0/27      1-4094
Fa0/31      1-4094
Fa0/46      1
Fa0/47      1-4094
Fa0/48      1-4094
Gi0/1       1
Gi0/2       1
Port        Vlans allowed and active in management domain
Fa0/23      none
Fa0/27      1
Fa0/31      1
Fa0/46      1
Fa0/47      1
Fa0/48      1
Gi0/1       1
Gi0/2       1
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/23      none
Fa0/27      1
Fa0/31      1
Fa0/46      1
Fa0/47      1
Fa0/48      1
Gi0/1       1
Gi0/2       1
APWNOGSW102# show span vlan 100
Spanning tree instance(s) for vlan 100 does not exist.
APWNOGSW102#
VIP Purple
Also you did not define vlan 100 on this 2960. Define this layer 2 vlan first
I did have it defined but then deleted it.  I will re-add it now.
VIP Purple
Also changed WLC trunk to a Gig port in the switch
I moved the WLC5500 connection to gi0/1.
APWNOGSW102#show run int gi0/1
Current configuration : 258 bytes
interface GigabitEthernet0/1
switchport trunk allowed vlan 1
switchport mode trunk
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
macro description cisco-switch
auto qos trust
spanning-tree link-type point-to-point
end
I also recreated the VLAN 100 on the switch.
VLAN0100
  Spanning tree enabled protocol rstp
  Root ID    Priority    32868
             Address     0cd9.9654.0000
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32868  (priority 32768 sys-id-ext 100)
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Fa0/27              Desg FWD 19        128.27   P2p
Fa0/31              Desg FWD 19        128.31   P2p
Fa0/47              Desg FWD 19        128.47   P2p
Fa0/48              Desg FWD 19        128.48   P2p
I noticed that the gi0/1 port wasn't showing for vlan 100, so I changed that.  Still not seeing any response to pings from the switch side or the WLC500 yet.... ;-(
APWNOGSW102#show span vlan 100
VLAN0100
             Aging Time  300 sec
Gi0/1               Desg BKN*4         128.49   P2p *PVID_Inc
Here is what it looks like now.
APWNOGSW102#show interfaces gi0/1
GigabitEthernet0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0cd9.9654.0031 (bia 0cd9.9654.0031)
  Description: WLC5500
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX
  Last input 00:00:00, output 00:00:01, output hang never
     35726281 packets input, 7607357050 bytes, 0 no buffer
     Received 2138152 broadcasts (1203919 multicasts)
     0 watchdog, 1203919 multicast, 0 pause input
     36863144 packets output, 21929997593 bytes, 0 underruns
APWNOGSW102#show interfaces gi0/1 trunk
Gi0/1       on               802.1q         trunking      100
Gi0/1       100
Gi0/1       100
Gi0/1       none
VIP Purple
Allow vlan 100 in ur trunk
VIP Purple
I noticed ur 2960 switch is root for vlan 100. Root shoul be the switch where gateway defined for vlan 100. Make sure vlan 100 exist in all switches and allow it across trunk links upto root. I think that is the only missing part
Let me verify what you are saying:
1. The switch that is connected to the WLC has VLAN100 defined on it.
2. All other switches need VLAN100 defined on them separately.
3. All Trunk Links should allow "ALL" (in my case that is ok since I'm replacing VLAN1 with VLAN100).
Is that sound correct?
VIP Purple
Hi Rob,
1. Go to the switch where you defined SVI for vlan 100 (ie 10.29.1.245). Make sure vlan 100 defined on that switch & that switch become the root for vlan 100. If you haven't configure spanning priority for that vlan in that switch then following command will ensure this switch become root always for vlan 100
"spanning-tree vlan 100 priority 0"
2. Then see how your 2960 switch connected to this SVI defined switch. If it is directly connected then you should be fine. If not, you have to define vlan 100 in transit switches till you go back to 2960.
3. If turnk ports allow all vlan for inter-switch trunk links at the moment leave as it is, you do not want to manually add vlan 100 in that case
once you do this & then go to 2960 switch & run "show span vlan 100". If everything correct you should see your SVI defined switch mac address as root.
Hope this clear, if not let me know
Rasika
The 10.29.1.245 is our gateway to the WAN (Cisco 2800).  I cannot make changes to it because it is owned by ATT.  What do you suggest in this case?
VIP Purple
Ok,if that is the case how 2800 connected to your switches ? Is it directly connected to 2960 or not. Please let us know..
then will help you
10.29.1.245 is directly connected to 10.29.100.100 which is the same switch that the WLC5500 (and WLC4400) are connected to.
VIP Purple
Ok then it would be easy.
Check in your 2800 "show ip int brief | ex un" output & post it here.
also show run int g0.100 (or correct subinterface) config where you defined this gateway address
I cannot login to 10.29.1.245 to run any commands.  I do have a copy of the configuration from it.  Here is a subset of the interface settings. Is this what you wanted to see?
interface FastEthernet0/0
description $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
ip address 10.29.1.249 255.255.0.0
ip policy route-map INTERNETDSL4
speed auto
full-duplex
vrrp 1 description primary active GRP 1
vrrp 1 ip 10.29.1.245
vrrp 1 preempt delay minimum 20
vrrp 1 priority 110
vrrp 1 track 1 decrement 15
no cdp enable
no mop enabled
service-policy output voice
I am not sure I understand the second request.  Here is the information from the 10.29.100.100 switch for the port that connects to the WLC5500, gi0/1.
APWNOGSW100#show run int gi0/1
Current configuration : 300 bytes
description WLC5500
switchport trunk native vlan 100
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
end
VIP Purple
Hi Rob,
I still see a mistake in G0/1 of your 2960 as you made vlan 100 as native. Remove that config line
Int g0/1
no switchport trunk native vlan 100
switchport trunk allowed vlan 100
From your 2960 switch can you ping 10.29.1.245 ? If not we need to fix that first.
let me know
Ok, I remove vlan100 as native.  In the GUI, it made me enter 1 as the native Lan.  Is that ok?
The 2950 switch at 10.29.100.100 can always ping 10.29.1.245.  It just can't ping the WLC5500 at 10.29.1.242 (which is connected to its the gi0/1 port.  Nor can the WLC5500 ping anything.
I will be traveling tomorrow for part of the day, but feel free to reply.  Thanks for all of the suggestions so far!
VIP Purple
wait, you said change it via GUI ?  You should only change the 2960 G0/1 configuration & not WLC end
See wether it make any difference
545
