Community Member
java error when starting wcs
Can anyone help with the following error im getting when starting wcs
Many thanks
Lee
[root@netmon bin]# ./startServer.sh
JAVA_HOME=./../jre
Checking for Port 21 availability... OK
Checking for Port 8456 availability... OK
Checking for Port 8457 availability... OK
Checking for Port 1299 availability... OK
Checking for local Port 1299 availability... OK
Checking for Port 6789 availability... OK
Checking for local Port 6789 availability... OK
Checking for UDP Port 69 availability... OK
Checking for Port 8005 availability... OK
Checking for UDP Port 162 availability... OK
Checking for Port 8009 availability... OK
Starting RMI registry on port 1299
Registry started.
DB is already started
Starting NMS Server...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /opt/WCS4.2.97.0/webnms/RFdlls/librfeng.so: Can't load IA 32-bit .so on a IA 32-bit platform
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at com.cisco.server.map.RfPredictionServiceHelper.initialize(Unknown Source)
at com.cisco.server.map.RfPredictionServiceHelper.<init>(Unknown Source)
at com.cisco.server.map.RfPredictionServiceHelper.createInstance(Unknown Source)
at com.cisco.server.startup.NmsServer.initialize(Unknown Source)
at com.cisco.packaging.NMSMain.runMain(Unknown Source)
at com.cisco.packaging.NMSMain.main(Unknown Source)
1 REPLY
Silver
Re: java error when starting wcs
Looking at the logs and the exception it appears that it is java related. Can you try upgrading your current version of Java.
294
