LAG on WLC5508
Hello guys
i have a wlc 5508 , and i want to enable LAG, but i want to connect 4 ports in one module and the rest 4 ports in another module,
for example
Gigabitethernet1/45 - 1/48
Gigabitethernet3/10 - 3/13
both modules in the same core switch (6506) obviously using the same port channel , so at the end i would have redundancy between modules for when a module fails.
the question is, can this be done?
or all the 8 ports needs to connect to the same module, ?
i mean 1/40 - 1/47 for example...
Thnks!!!!
1 ACCEPTED SOLUTION
LAG on WLC5508
Luis,
     you can split the ports across multiple modules in your switches.  THe only thing you can't do is spli the lag across multiple switches, unless VSS.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hall of Fame Super Silver
Re: LAG on WLC5508
If you are running VSS between the two cores you would be able to split the port channel.
-Scott
LAG on WLC5508
Luis,
Steve
Bronze
LAG on WLC5508
Luis,
You can connect the 8 ports to the two modules if they are stacked modules, which means they under the same management IP. If you want to use two separate switches, then you would must run VSS.
LAG on WLC5508
Thnk you guys,
i'll served a lot your help
greetings !!!
289
