01-29-2004 01:43 AM - edited 07-04-2021 09:19 AM
On a single Access Point, can you run Cisco LEAP authenticating some supplicants to a Cisco ACS server as well as running EAP, authenticating another group of supplicants to a Microsoft RADIUS server?
Solved! Go to Solution.
02-01-2004 01:47 PM
Yes, the AP is configured exactly the same for EAP, PEAP, LEAP, etc, etc. Its the client and the radius that have seperate configs. We are using LEAP and PEAP in conjunction and the AP requires no different configs to support each. So to answer your question, yes you can.
02-01-2004 01:47 PM
02-01-2004 01:48 PM
To achieve this you must define seperate SSID's for each with it authenticating to a seperate server.
