Leap configuration with Broadcastkey rot.
I have a short question about leap config and broadcastkey roation.
What do i really need. if i use tkip and mic i dont really need to configure boradcast key roation am i right?
When i configure bc key rot. i set an interval with i also set on the acs. (eg. 600)
when i dont want to user broadcastkey rot. so i dont set the interval do i need the to set the [027] Session-Timeout on the acs for the leap wep key rotation?
is that the time when the user gets a new wep key?
or where do i set the time for dynamic wep keys?
regards Bernhard
Not applicable
Yes you are right, WEP key rotation is used as an alternative for TKIP if we have non-cisco clients trying to connect.
