Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Legacy non N clients connecting to 5ghz radio
I just setup an Autonomous 1140 AP.  I want to keep my older clients connected to teh 2.4ghz radio and the N clients connected to the 5ghz radio.  I have set the 5ghz radio to have a channel width of 40mhz and above however a laptop with a g card can connect to this SSID/radio just fine albeit just at 54mbps.  Any recommendations on how to lock this down?
Everyone's tags (5)
Hall of Fame Super Gold
Re: Legacy non N clients connecting to 5ghz radio
Don't use 40Mhz channel bond.  Use the 20Mhz if you don't have high-bandwidth.
we do have high bandwidth, it's connected to a gig port on the core.   If i dont use  40mhz then i wont see the 300mbps for the N clients right?  Id rather not saturate this radio with the older clients, a/b/g and just have it reserved for the N clients.  My concern is that older clients will be able to connect to it.  I do have a non n client that has a dual band nic in it, i believe it does b/g and a.  I disabled the a portion and now it connects to the 2.4 ghz radio.  Do a and n clients always connect to the 5ghz if it's available?
Have a read at this document entitiled "Configure 802.11n on the WLC".  I know it's for controller-based but it's still an interesting read, nontheless.  Verify the client settings to see if it's configured for 802.11n.
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080a3443f.shtml#topic8
perhaps i have misspoke.  N clients can connect and get HT speeds, 300mbps.  So i dont have an issue with N clients connecting.  G clients can connect as well.
I would like to prevent non N clients from connecting to the 5ghz radio.  Anyone know of a way to do this?
G clients won't be connecting to that 5 GHz radio as they don't have a 5 GHz radio in them. I assume what you mean is that a/b/g clients are connecting to the 5 GHz radio, therefore the making use of their 5 GHz capability.
Cisco doesn't support the ability to exclude 802.11a clients at the moment (hopefully some day) and therefore I am preventing their connection with a script that disables the 802.11a radio forcing them to use their 2.4 GHz radio and connect to the 2.4 Ghz SSID I have setup.
1187
