Community Member
Lightweight AP Syslog Level
Does anyone out there know if there's a way to control the syslog level lightweight APs use for trap logging? I know it's possible to configure them to log to a particular host instead of the default of the 255.255.255.255 but I can't find any command or option to change the trap logging level. It apparently defaults to emergencies and I'd like to set to informational instead to capture additional log data.
Brandon
Everyone's tags (2)
1 ACCEPTED SOLUTION
VIP Purple
Re: Lightweight AP Syslog Level
Below should help you to do this. If you want to do it for a AP then you need to type AP name instead of all. Also make sure APs get register to your controller before doing this.
config ap logging syslog facility   all
config ap logging syslog level informational all
config ap syslog host global
You can verify by using below commands
show ap config global
show logging
show ap config general
Rasika
VIP Purple
show logging
Rasika
Community Member
Yep that's what I was looking for! Thanks! Next time I'll RTM more closely
-Brandon
VIP Purple
Great.. Thanks for rating the response
540
