Linksys WET54GS5 and WPA
Have anyone a clue how to use WPA with radius on Linksys WET54GS5 wireless brigge to Aironet AP1231G with Cisco ACS3.2 as radius? Can get WPA-PSK to work but authentication fails if i try the bridge to use WPA-Radius. Have tried to use both TLS and TTLS and copied a certificate from a Windows XP laptop without success. Doesn quite know how to figure this out.
  • Security and Network Management
Re: Linksys WET54GS5 and WPA
In researching WPA and WPA2 products, I believe the WET54GS5 only supports WPA-PSK. I'd love to have this product (or any workgroup Bridge) with WPA2 Radius...
What does anyone do with WPA/2-Radius if you don't have a certificate server?
Agree with you! Just got a cheap CNet CWA-854 that can be set i client mode, but that did only support WPA2 in AP mode... Earlier we had to be a research lab just ordering all types of pcmcia cards that could do a properly job and now its bridges we try to investigate. The WET54GS5 is perfect with the built in switch and costs nothing compare to a Cisco bridge/ap + a switch. Its also very tiny.
402
