Community Member
Lobby Ambassador in WCS and Guest Controller
Is there anyway to use the Lobby Ambassador function in WCS to create guest accounts only on the guest (mobility anchor) controller. When the lobby administrator creates an account in the WCS it creates the account on the controllers with the access points attached, but not on the mobility anchor controller in the DMZ. It would be nice to just have the lobby ambassadors access the controller in the DMZ and not hit the WCS, but in this environment that is not possible.
Re: Lobby Ambassador in WCS and Guest Controller
Depends on the version of WCS you are running. In 4.1, when a Lobby Admin logs in to create an account, you change the drop down to be Controller List, and you can select which controllers to push the template to.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Community Member
Thanks for the heads up. I had a case of the D&$%a**.
197
