10-08-2014 03:35 AM - edited 07-05-2021 01:41 AM
On my controller have multiple SSID configured, mac filter is also enabled, now i want to add one MAC address for two SSID.
Pls any one help on this.
Nafis Ashique
10-08-2014 03:48 AM
Go to Security > AAA > Mac Filtering
Then clcik on New.
Here put the MAC address, select Any Profile, Interface-None and leave empty other option.
Dont forget to rate helpful posts
10-08-2014 04:08 AM
Hi Sandeep,
Thanks for your Quick reply.
Suppose mac address is aa:aa:aa:aa and my ssid is a1, b1 and c1, now i want to do aa:aa:aa:aa can only connect a1 & b1 but not on c1.
As per your reply aa:aa:aa:aa can connect on every SSID.
Nafis Ashique
10-08-2014 04:20 AM
I think this cant be done on wlc alone, you must ahve a RADIUS server for this.
You must use: RADIUS-Based VLAN Access Control
10-08-2014 04:25 AM
Ok,
if you have any document for the same pls put the url Link.
Nafis Ashique
10-08-2014 05:17 AM
check these:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/71683-dynamicvlan-config.html#switch
https://supportforums.cisco.com/document/15431/how-implement-radius-based-vlan-access-control-features-access-point
