MAC-based ACL in wireless router
I have a AIR-AP1262N wireless rotuer. I have implemented many mac based ACL in it. A sample looks like this.
access-list 715 permit 6427.37e0.8379   0000.0000.0000
access-list 715 permit e006.e933.901d   0000.0000.0000
access-list 715 permit 88cb.8278.40e8   0000.0000.0000
access-list 715 permit 6427.37e0.d1ng   0000.0000.0000
access-list 715 deny   0000.0000.0000   ffff.ffff.ffff
Now what ever new mac I want to allow, the acl that I configure is going below the deny rule and it is not working.
Is there any way to move it before the deny rule or should I delete the whole config and re-enter it every time.
  • Security and Network Management
Re: MAC-based ACL in wireless router
You would need to call the line number in the ACL to insert it above.
So if you rewrite the ACL and call the dent as 100 , you would be able to add above it
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Type Show Ip access-list and check the line number above which you want to enter the new conditional statement and then use ip access-list command with line number to insert it above as explained by Stephen.
Thank you Stephen and Ravi.
But this is a mac based ACL. So when you tye in sh ip access-list, this will not show the resuls with line number.
Please try the below commands and update that it is working or not
show mac access-lists name
and then
resequence mac access-list name starting-sequence-number increment/decrement
273
