07-20-2012 12:23 PM - edited 07-03-2021 10:26 PM
I'm deploying several hundred handheld scanners and I dont want to create a mac filter for everyone, however that are all the same manufacturer, and that manufacturer only has one mac prefix, is there a way to just put the mac prefix in? I'm using 5508's running 7.0.116.0.
Help files and searches turned up nothing.
Thanks.
07-20-2012 02:07 PM
Ryan:
This is unfortunately not available.
It will be great feature if provided but cisco still not doing that.
07-20-2012 04:25 PM
If you have a radius server like acs 5 you can put your Mac list on the radius server and you can do mab, mac address bypass. Now I haven't don't this myself, but this will give you somewhere to look further.
07-21-2012 02:54 PM
MAC filtering only method of security is not secure, also mac filtering is useless since the mac addresses are visible on w.less packet capture and it can be spoofed.
06-16-2013 11:45 PM
My problem is the opposite. I would like to ban / disable mac address begining to a given manufacturer because:
- my wireless clients are of the same manufacturer
- someone is scanning repeatly during months with hundreds of different fake mac address -but all of them begining with 00:0e:8e- and they are highly populating the excluded client table.
I suppose there is no solution for that until now
Jose
06-17-2013 03:02 AM
There is no wildcard for Mac filter. The whole MAC address has to be entered.
06-17-2013 10:30 PM
Please check the following link which describes how to use MAC filters with WLC.
"MAC Filters with Wireless LAN Controllers (WLCs) Configuration Example"
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008084f13b.shtml
04-29-2014 12:23 PM
If you wish to deny access to a single wireless client by using their MAC address - use the following command from the CLI on the WLC: config exclusionlist add <enter mac address> <description>
This was in response to j.vazquez.c issue.
10-22-2014 09:22 AM
This feature is not available.
