MAC Filterin, WLC and Freeradius
Hi guys: Im having some problems trying to setup a WLC filtering users by MAC Address using a Free Radius servers.
Currently i'm using autonomous APs and its working just fine, the configuration for this is:
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.63.4 auth-port 1812 acct-port 1812 key 7 ************
radius-server vsa send accounting
Now, using LWAPP, I have configured the WLAN for None Security in layer 2 and 3, and checked the Mac Filtering box. Also, I added the Radius server under the security tab, added "free radius" compatibility and the same shared secret used with the autonomous APs.
The radius server is expecting the user/password to be mac_address/mac_address. But it looks like the controller its sending "mac_address/shared_secret". In the controller i get the following messages (they are from different debugs and logs):
7 [ERROR] radius_db.c 1073: 8th AVP is corrupted. Radius msgtype=0. Prev AVP=1 len=4 offset=120 numAVPs=14.
Wed Mar 21 12:06:07 2007 [ERROR] radius_db.c 804: BAD aaa AVP with NULL value pointer.(code=2, valueLen=0, vendorId=0,buf=0x11cce05c, bufSize=3976)
Wed Mar 21 12:05:55 2007 [ERROR] radius_db.c 1073: 8th AVP is corrupted. Radius msgtype=0. Prev AVP=1 len=4 offset=120 numAVPs=14.
Wed Mar 21 12:05:55 2007 [ERROR] radius_db.c 804: BAD aaa AVP with NULL value pointer.(code=2, valueLen=0, vendorId=0,buf=0x11cce05c, bufSize=3976)
(Cisco Controller) >Wed Mar 21 11:28:50 2007: 00:14:a5:b8:a3:0d Successful transmission of Authentication Packet (id 129) to 192.168.63.4:1812, proxy state 00:14:a5:b8:a3:0d-a5:b8
Wed Mar 21 11:28:50 2007: ****Enter processIncomingMessages: response code=3
Wed Mar 21 11:28:50 2007: ****Enter processRadiusResponse: response code=3
Wed Mar 21 11:28:50 2007: 00:14:a5:b8:a3:0d Access-Reject received from RADIUS server 192.168.63.4 for mobile 00:14:a5:b8:a3:0d receiveId = 0
Wed Mar 21 11:28:50 2007: 00:14:a5:b8:a3:0d processing avps[0]: attribute 18
Wed Mar 21 11:28:50 2007: 00:14:a5:b8:a3:0d Successful transmission of Authentication Packet (id 130) to 192.168.63.4:1812, proxy state 00:14:a5:b8:a3:0d-a5:b8
Wed Mar 21 11:28:51 2007: 00:90:96:cb:3a:e1 Successful transmission of Authentication Packet (id 131) to 192.168.63.4:1812, proxy state 00:90:96:cb:3a:e1-96:cb
Wed Mar 21 11:28:51 2007: ****Enter processIncomingMessages: response code=3
Wed Mar 21 11:28:51 2007: ****Enter processRadiusResponse: response code=3
Wed Mar 21 11:28:51 2007: 00:90:96:cb:3a:e1 Access-Reject received from RADIUS server 192.168.63.4 for mobile 00:90:96:cb:3a:e1 receiveId = 0
Wed Mar 21 11:28:51 2007: 00:90:96:cb:3a:e1 processing avps[0]: attribute 18
Any suggestions? Thanks in advance :)
Bronze
Re: MAC Filterin, WLC and Freeradius
Remove any incorrect proxy server configured. This might redirect the request to wrong AAA server.
Problem was solved. What I changed was the format of the mac address, from this xxxxxxxx to xxxx-xxxx. Anyway the server was configured to accept both, but for some reason it didnt work using the first format.
Hi  omarmontes,
I'm trying to deploy the same configuration like you, I work with wlc 5508 and FreeRadius, could you tell me how you save MAC address on FreeRadius?
1324
