Community Member
MAC Flaping After I Trunk AP Uplink
I have configued all my APs to Transmit the SSID on VLAN 204, with the management IP is in VLAN 98. Client are authicating but now I get syslog messages stating I have MAC FLapping betteewn the uplink of the AP and the switch uplink. I don't now what is cauing this. Here is the error.
1187. xxx.xx.131.122 xxx.xx.131.122 Dec 01 2008 12:17:00 SW_MATM 4 MACFLAP_NOTIF Host 0013.cea3.750f in vlan 204 is flapping between port Fa0/17 and port Fa0/5
How does one solve this?
MIke
1 ACCEPTED SOLUTION
Community Member
Re: MAC Flaping After I Trunk AP Uplink
the command spanning-tree portfast on the trunk links is creating a problem, remove that and check on
Community Member
What is configured on your Fa0/17 and Fa0/5?
Community Member
Here are the configs:
interface FastEthernet0/5
switchport access vlan 58
switchport trunk native vlan 58
switchport mode trunk
speed 100
duplex full
interface FastEthernet0/17
switchport access vlan 63
switchport trunk native vlan 63
speed 100
duplex full
They are both trunk for cisco switch which have a 1100 series AP connected to it.
Mike
Are the APS lwapp or autonomous? If they are lwapp, the switch ports should be in access mode in the same vlan as wlc management interface or a vlan that can access the WLC mgmt interface.
Community Member
No they are all in Autonomous mode.
Mike
Community Member
376
