Mac OS X 10.4.5 issue
We have a machine intel core duo macbook pro machine running mac OS X 10.4.5. We are using encryption IEEE802.1x WEP with PEAP-mschapv2 authentication.
The authentication passed. And a show dot1 association all-clients have the correct ip address for the mac OS X client. However, a ifconfig at the macbook pro machine show 169.254.x.x (not able to get ip address from dhcp server).
We have tried successfully with WPA2/AES with PEAP-mschapv2. We got the correct ip address when issue ifconfig.
Did anyone has meet similar problem?
Any advise is highly appreciated.
Silver
Re: Mac OS X 10.4.5 issue
Check the option 43 in DHCP server, Verify the vlan configuration
not sure how option 43 in DHCP server can help, can you explain a little bit more.
I have my support staff all telling me they've been unable to the new Intel Macs onto the network. So I too am having the same problem. (I just have not expericanced first hand, no Mac laptops for me)
I had problems with Macbook Pros using 802.1X EAP-PEAP. The following resolved the problem:
Upgrade to 10.4.6
http://www.apple.com/support/downloads/macosx1046forintel.html
Upgrade to the latest firmware
http://www.apple.com/support/downloads/macbookproearly2006firmwareupdate101.html
Sometimes for 802.1x to work properly on a Mac you need to use the Internet Connect utility (in Applications > Utilities). From there choose File and New 802.1x Connection.
183
