Management Frame Protection
Should I set MFP to required on my WLANs and under the AP authentication within Wireless Protection Policies on my WLC?
Currently running 7.3.112.0 but will shortly be upgrading to 7.4.110.0.
Will it cause any client issues?
VIP Purple
Re: Management Frame Protection
I would keep client MFP "disabled" or "optional" under WLANs advanced settings.
Infrastructure MFP you can keep enabled by either selecting "AP authentication" or "Management Frame Protection" if you really require to provide security for infrastructure management frames.
This describe client MFP issues with windows 8 environment. Read this & see if it relates to your environment
http://blogs.cisco.com/wireless/get-your-wi-fi-network-ready-for-windows-8/
Rasika
Hall of Fame Super Silver
I agree with Rasika.... This is something like all or none. If all your devices can't support it, then why do it as it will break things. Also if you don't run it in all your SSID's, why do it just for one. It goes back to, would a person who wanted to access your network, try to access it from a more secure SSID or a lesser secure SSID. Of course it's the lesser. Vendors have features and they have to follow with certain technologies, but as we know, not all vendors devices work well with these new/old features and device manufactures don't always have to follow specifics.
-Scott
408
