MBP dropping connecting on 887w
I have a 887w with intergrated wireless and it keeps on dropping my macbook pro.
Below is the configuration.
Any thing that is glaring that I should change?
[code]
Building configuration...
Current configuration : 2884 bytes
version 12.4
no service pad
hostname ap
logging rate-limit console 9
enable secret 5 $1$3It1$NoWM5fCF87TM//gLz1Npq.
no aaa new-model
dot11 syslog
dot11 ssid Colts-2006
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 0 [password]
username cisco privilege 15 secret 5 $1$15se$qlcsjqiD02G9U.nnzjxWm.
ip scp server enable
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid Colts-2006
antenna gain 0
station-role root access-point
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.100.5 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner exec ^CC
% Password change notice.
Default username/password setup on AP is cisco/cisco with privilege level 15.
It is strongly suggested that you create a new username with privilege level
15 using the following command for console security.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to
use. After you change your username/password you can turn off this message
by configuring  "no banner login" and "no banner exec" in privileged mode.
^C
banner login ^CC
no username cisco
^C
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
cns dhcp
end
[/code]
Hall of Fame Super Silver
Re: MBP dropping connecting on 887w
Try only using AES-CCM... Should use TKIP with wpa2
-Scott
awesome thank you.
However now my wifi is asking for username/password,
How do I do just a password key?
Delete the wireless profile from your MBP and click on the ssid again. It should ask you just for the password/pre shared key.
-Scott
By the way, since you made a change to the ssid, it might be better to remove all existing wireless profiles on your other devices also and create it again.
-Scott
149
