Minor Alret at prime infrastructure 2.0 about mismatch configuration.
Dears,
kindly i have minor Alert at prime infrastructure 2.0 (Audit done at '2013-nov-28,05:00:00 CET'..config difference found between NCS and Controller),
what this error and please feed me back with steps to solve this problem.
Hall of Fame Super Silver
Re: Minor Alret at prime infrastructure 2.0 about mismatch confi
The WLC and PI don't sync... So if you make a change to your WLC, eventually when PI pills the WLC, there will be a mismatch. To clear the mismatch, you just need to refresh the configuration from the WLC on PI.
-Scott
Thanks Scott can you advice with steps
VIP Purple
Hi Ahmed,
adding to Scott:
Login in Prime Infra.
First check your theme(Classic or Lifecycle).......Go to Root and see the Theme.
There are steps for classic theme
Go to Configure> Controllers
and then which controller have config mismatch...on right side click on mismatch in Audit status tab.
After that it will ask for audit now, click on that. After auditing it will show you the two option:
1. Restore PI values to Controller
2. Refresh config from controler
Clcik on 2nd #Refresh config from controler#
Then select 2nd option again(Use the configuration on the controller currently) and click on GO.
Dont forget to rate helpful posts
thanks i will try and feed back you, but please can you tell me if i choose #Refresh config from controler# this is will need down time or not.
VIP Purple
HI Ahmed,
No need.....for downtime.
It will just updated the config on PI from controller.
Cool!this two year old post
Cool!
this two year old post solved my current "config difference found between NCS and Controller" problem.
Thanks, Sandeep!
Hi Sandeep,
Hi Sandeep,
Thanks for your support, I am getting same message and now it is resolved.
935
