Missing RX neighbours in WCS
I've recently upgrade the wireless infrastructure to the latest versions of code. but since doing that when, i go into the monitor page for an access point in the wcs at the bottom it should show all the other access point it can see and their signal strength but now its not showings anything. i think this could be causing problems with our location applience as our tracking has gone a bit screwey. any ideas?
Currently using 1242 Lwap ap's
4404 wireless lan controllers
2700 location appliance and a wireless lan controller. all running the latest version of code.
Thanks all
Adam
Re: Missing RX neighbours in WCS
What version of WLC code?
5.1.64.0 running on a windows 2k3 server
and for information
the ap's are running 5.1.151.0
the WLC's are running 5.1.151.0
the location appliance is running 5.1.30.0
This is a known issue documented in release notes of 5.1. This should not impact location accuracy.
CSCsr27204-Rx neighbor information is missing from the Monitor > Access Point window when you choose an active access point and click on either radio.
Workaround: The Rx neighbor and other similar information is available from the Maps page. If you hover over the access point in Maps for each radio tab, an Rx neighbor link shows the complete information.
218
