Mixed vendor wireless cards
I am trying to find what vendors wireless cards will work with the Cisco 1200 access points that will be using an ACS server to authenitcate. I know that the Aiport Extreme and the Linksys WPC55AG supports LEAP.
Does anyone know of other vendors that support LEAP/EAP?
1 REPLY
Re: Mixed vendor wireless cards
It all depends on if you want EAP or LEAP
If you want LEAP then you need a card that is Cisco CCX certified
http://www.cisco.com/en/US/partners/pr46/pr147/partners_pgm_concept_home.html
http://www.cisco.com/en/US/partners/pr46/pr147/partners_pgm_partners_0900aecd800a7907.html
This list has a number of cards that are waiting completion of testing to be listed so make sure you check back over time
150
