Mobile phone not able to connect
We use 2504 WLC. Attached are the AIR-CAP-1602 Acces Points. We secured all our WLAN networks with WPA/WPA2 and PSK. We're able to connect to these WLAN's with a Nokia Lumia or Sony Xperia J/S. When we try to connect with a HUAWEI or Iphone5 the phone keeps "connecting" or "getting IP".
I tried following:
- change MTU,
-  disable 5ghz,
- disable 2.6 ghz,
- Disabling security on the WLAN's
- DHCP proxy enabled
None of the above made any difference.
Anyone?
1 ACCEPTED SOLUTION
VIP Purple
HI Try to use only one type of authntication:
Either
WPA2/AES
or
WPA/TKIP
and then try again.
Dont forget to rate helpful posts
VIP Purple
Either
WPA2/AES
or
WPA/TKIP
and then try again.
VIP Purple
Post "show wlan " output to see the current settings of your WLAN.
Rasika
Re: Mobile phone not able to connect
Wlc code?
Try Toggling dhcp required, fast ssid.
Get
Debug client mac-addr
Debug dhcp message enable
what WLC code you are using.? We recommand you to use 7.0 or higher.
We'll try all the options, thanks!
I've tried following:
- Toggle Fast Transition to enable
- Change security to WP2 AES (PSK)
These settings made it possible to connect with all iphones.
Thanks!
VIP Purple
Glad that our posts helped you.Thanks for rating.
329
