Community Member
Mobility Group problems
Hi All,
My mobility group members state on their logs that the data paths to the other members is up but from the CLI I'm seeing that the control path is down. The debug mobility keep-alives output is (edited out IP address)
Thu Sep 20 16:05:51 2007: EOIP Keepalive received from: 172.a.a.190
Thu Sep 20 16:05:51 2007: version : 01, opcode : ETHOIP_OP_RESP sequence no. 3694 peerStatus: 0
Thu Sep 20 16:06:01 2007: EOIP Keepalive sent to: 172.a.a.190
Thu Sep 20 16:06:01 2007: version : 01, opcode : ETHOIP_OP_REQ sequence no. 3697 peerStatus: 1
Thu Sep 20 16:06:01 2007: Mobility Member 172.a.a.190 detected DOWN status 2,cleaning up client entries
Thu Sep 20 16:06:01 2007: EOIP Keepalive received from: 172.a.a.190
Thu Sep 20 16:06:01 2007: version : 01, opcode : ETHOIP_OP_RESP sequence no. 3697 peerStatus: 0
Thu Sep 20 16:06:11 2007: EOIP Keepalive sent to: 172.a.a.190
Thu Sep 20 16:06:11 2007: version : 01, opcode : ETHOIP_OP_REQ sequence no. 3700 peerStatus: 1
Thu Sep 20 16:06:11 2007: UDP Keepalive sent to ::
Thu Sep 20 16:06:11 2007: 172.a.a.190, port 16666, Switch IP: 172.a.a.190
Thu Sep 20 16:06:11 2007: type: 20(MobilityPingRequest) subtype: 0 version:1 xid: 1247 seq: 1247 len 40 flags 0
Thu Sep 20 16:06:11 2007: group id: d8e610a6 73843359 e0b6cb87 2f245624
Thu Sep 20 16:06:11 2007: Mobility Member 172.a.a.190 detected DOWN status 2,cleaning up client entries
There are no firewalls between the controllers - have I missed a config step somehow?
As usual any help you can give will be greatly appreciated
Thanks in advance
Scott
Community Member
Re: Mobility Group problems
I would consider whether or not the mobility domain setting is correct. I had an issue where the mobility group was defined properly but the mobility domain was not. All clients were able to roam, but I kept getting similar errors. I changed the Mobility Domain name to the same name as the Mobility Group and the error stopped. You can find this setting in the Wireless Control System. Browse to Configure>Controllers, select the individual controllers and the setting will be displayed under the "System" tab.
Community Member
Hi Robert,
Thanks for your response. Yours may well have been the answer but I cannot remember as it was so long ago.
Scott
Hello Soctt,
Please mark the Question as Answered, if the provided information is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Thanks & Regards
Community Member
Hi Vniay,
As I've stated above, it was some time ago (six years) so I do not recall what the solution was.
Scott
525
