Community Member
Mobility Issue - " Control and Data Path Down"
Dear Team,
I am trying to configure the mobility groups in my 2 Cisco 5508 WLC running with code 7.4.110.0.   Both of my controller management Ip is reachable and both WLC virtual ip is configured with 1.1.1.1.  I completed below steps to configure the mobility groups
1) Created new mobility group with Name "Mobiltiy" in both contoller.
2) management and mac address has been assigned respectively.
3) Not configured the multicast option, however after enabling multicasting option with the Ips 239.0.0.2 and 239.0.0., it is not working.
I am getting the mobility status as "Control and Data Path Down", where I am able to ping the both the WLC each other. Kindly help me to resolve this issue.
Jubair.S
1 ACCEPTED SOLUTION
VIP Purple
Still you have diff local
Still you have diff local mobility group name on both wlc.
wireless1 pic shows: copr.sva.com
wireless1 pic shows: default
Try to be in same mobility group name.
Gold
Hi Jubair,Do you have any
Hi Jubair,
Do you have any firewall or acl blocking the ports between the WLC's?
Have you configured mobility group configuration on the both WLC's are per below procedure?
http://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/7-4/configuration/guides/mobility/config_mobility.pdf
Najaf
Gold
Hi Jubair,Could you please
VIP Purple
 You have Name on:1st wlc:
You have Name on:
1st wlc: corp.sva.com
2nd WLC: Mobility
Can you put both controller in same Mobility group name and then try it.
Hope it helps.
Community Member
dear Sandeep, Screen shot is
dear Sandeep,
Screen shot is attached for one of the WLC screen shot. corp.sva.com is the default mobility group in the WLC and Mobility is the  name we have defined manually for mobility group. Please find the both WLC screen shot as attached. Both the controller is in the same mobilty group name only. Kindly check the attachement.
dear Najaf,
There is no ACL/firewall in between these WLC. I configured as per the attached document only.
Jubair.S
Community Member
Dear Team, I tried to conduct
Dear Team,
I tried to conduct mping and eping, which is not working. Kindly let us know what is missed in my configuration.
VIP Purple
Community Member
Thanks a lot Sandeep, It is
It is working fine now....
496
