mse(VM) not discoverable by Prime Infrastructure
                   upon bootup and stopping the mse server, I receive the following error messages:
iptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
looking at the interface: ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:50:56:BA:15:71
          inet addr:10.24.109.14  Bcast:10.24.109.255  Mask:255.255.255.0
          inet6 addr: fe80::250:56ff:feba:1571/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:3777 errors:0 dropped:0 overruns:0 frame:0
          TX packets:129673 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:290408 (283.6 KiB)  TX bytes:18890381 (18.0 MiB)
eth0:1    Link encap:Ethernet  HWaddr 00:50:56:BA:15:71
          inet addr:10.24.109.16  Bcast:10.24.109.255  Mask:255.255.255.0
  <<<<parts removed to shorten post>>>>
I've tried flushing the iptables, but that command is not accepted:
iptables -F
Perhaps iptables or your kernel needs to be upgraded. iptables -F
Any suggestions?  Thanks
Rob:
What version of MSE software and Prime Infrastructure are you using?
Is this a new installation, or an upgrade?  If upgrade, from what to what?
hi Rollin Kibbe I have the
hi Rollin Kibbe
I have the same problem on new installation for MSE 7.4 ?
please advice
285
