Multi-MAC Filtering on Autonomus AP
Talal Abbas
Good day all,
I have a case where 5 Autonomous APs (1262 and 1130) need to use MAC access lists in a white-list kinda settup.
Basically, it should be as straight forward as:
access-list 700 permit xxxx.xxxx.xxxx
access-list 700 deny all
The problem: I have to filter 117 MAC addresses and I have to repeat this on all five of them.
To make things worse, this is in another city so I'm doing all of this using team viewer.
Is there a way for the AP to import a .xls or .txt file with some special format as an access list?
Talal Abbas
Sorry I forgot to mention that this will be used for association so I will also add:
dot11 association mac-list 700
To the interface
no, the AP doesn't take xml or csv as an import.
But you can cut and past the list into each one.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
