Bronze
Multiple SSID on 850 series
Hi there
Any one ever got 2 SSID's working on a 850 router?
I've done like this:
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
encryption vlan 2 key 2 size 40bit 0 0123456789 transmit-key
encryption vlan 2 mode wep mandatory
ssid Corporate
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii 7 <removed>
ssid guest
vlan 2
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
channel 2462
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
ip address 172.16.0.1 255.255.255.0
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 10.1.100.1 255.255.255.0
ip nat inside
ip virtual-reassembly
bridge 1 protocol ieee
bridge 1 route ip
But that makes the guest ssid not working. Corporate SSID works fine.
All I found was this link:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d289.html
But it tells me to bridge the vlan2 interface, however I can't have more then 1 Vlan on the 850 router.
Aaarh! What to do?
Does anyone know what to do?
Re: Multiple SSID on 850 series
In Cisco IOS Releases 12.4 and later, you can configure SSIDs globally or for a specific radio interface. When you use the dot11 ssid global configuration command to create an SSID, you can use the ssid configuration interface command to assign the SSID to a specific interface.
When an SSID has been created in global configuration mode, the ssid configuration interface command attaches the SSID to the interface but does not enter ssid configuration mode. However, if the SSID has not been created in global configuration mode, the ssid command puts the CLI into SSID configuration mode for the new SSID.
More information available at http://www.cisco.com/en/US/products/ps5853/products_configuration_guide_chapter09186a008067e9f6.html#wp1035858
Bronze
One thing try the following for the second vlan
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
add this to the confg below the Interface VLAN 1
interface Vlan2
no ip address
bridge-group 2
then finally
below Interface BVI1
interface BVI2
an IP adress should only be configured for Interface BVIx
hope this helps
in early version of code on that router...
when you did the following.
config t
vlan 2 (it would give an error) upgrade the code and then to the bridging you will be fine...
something like 12.4.11T1 etc would do fine.
We have now upgraded to IOS 12.4.11T2, now the vlan 2 can be created.
However, the bridging and bvi2 still doesn't work.
Here is our current config:
ip dhcp pool Corperate
network 10.1.6.0 255.255.255.0
default-router 10.1.6.1
dns-server 192.168.117.1 4.2.2.2
netbios-name-server 192.168.117.1
lease 2
ip dhcp pool GUEST
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 4.2.2.2 4.2.2.1
lease 2
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
encryption vlan 2 key 2 size 40bit 7 transmit-key
ssid GUEST
vlan 2
authentication open
guest-mode
ssid Corperate
vlan 1
authentication open
wpa-psk ascii 7
channel 2462
station-role root
bridge-group 1
bridge-group 2
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 10.1.6.1 255.255.255.0
ip nat inside
interface BVI2
ip address 192.168.0.1 255.255.255.0
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
Does anybody have an idea about what is wrong?
Try assigning the same ip address BVI2 has to Vlan2.
See if that solves the problem.
158
