Multiple SSID with AIR-AP1242AG & Fortinet router/firewall
We have AIR-AP1242 ap in our network and an Fortinet router/firewall.
We have no ap switch to manage all our ap.
We want to setup 2 differnt SSIDs in order to have an guest ssid over the DMZ and an internal SSID for LAN.
Is it possible with our materials? I think yes, but I'm not sure about the fact that we don"t manage all AP with a cisco switch..
I've found this link, and I think it's possible to setup our AP.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml
Thank you,
Hall of Fame Super Silver
Re: Multiple SSID with AIR-AP1242AG & Fortinet router/firewall
You can have multiple SSID mapped to different vlan's. The port that the AP is connected to needs to be a trunk port. So it depends on the switch you have. Here are other links that can help.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080c0b93c.shtml
http://jenniferhuber.blogspot.com/2009/12/how-to-broadcast-multiple-ssids-on.html?m=1
-Scott
Our network is :
Wan -> Fortinet router/firewall -> Cisco 2960/2950 Switch ->AP
        ->Clients computer
        ->etc
That's why I think that it's possible.
And, we had setup an DMZ with an VLAN30 for our FTP server over a cisco switch & fortinet firewall.
So we can confirm that it's ok, right ?
Yes it will work... Again, the port the ap is connected to needs to be a trunk port.
-Scott
yep, like a trunk port between switchs ?
661
