You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
multiple SSIDs and renaming a SSID
Can there be multiple SSIDs pointing to the same vlan/mob grp?
Also can one 'rename' a SSID that is already created or should it be wiped out and a new one recreated?
I assume each SSID needs to be tied to a VLAN unless one is a guest SSID. Can one have 2 guest SSIDs, in other words no security, but different SSID names?
  • Security and Network Management
1 REPLY
Silver
Re: multiple SSIDs and renaming a SSID
You must include at least two profiles in the Auto Selected Profiles Box. The profiles must specify an SSID; otherwise, they cannot be selected in the Available Profiles box. Profiles cannot specify multiple SSIDs; otherwise, they cannot be selected in the Available Profiles box. Each profile that is included in auto profile selection must have a unique SSID. For example,
if Profile A and Profile B both have "ABCD" as their SSID, only Profile A or Profile B can be included in auto profile selection.
177
